At the moment, DNSSR is basically nothing yet (aside from a few subdomains…)
So, the DNSSR sub-platform—DNSBoot (finally found a use for this weird domain)—is starting to take shape.
This platform will offer the following services:
Virtual hosting (limited by supabase, probably 1MB per user, enough for things like HTML)
Subdomains (won’t be synchronized with DNSSR, and there will be other domains available that you can bind to your virtual host)
DNS hosting (this one’s a bit tricky, might take a long time before it’s ready)
Hope everyone can support us! If possible, I’ll try to apply for PSL inclusion with aq.gl
I mean, if you can casually drop dozens of bucks on domains, grabbing a big hosting plan should be a breeze. 1M bandwidth is really just for static pages
