Collected some K12team resources being shared online, quickly set up a site, feel free to use it—$100 credit for everyone, it's all free anyway
:link: Site Address
API Address:
Sub2API - AI API Gateway
If you’re using software that supports the OpenAI API format, you can configure it directly as an OpenAI-Compatible API.
:white_check_mark: What is it suitable for?
  • Relaying models such as ChatGPT / Claude / Gemini / Codex
  • AI programming tool integration
  • Clients such as Cherry Studio / NextChat / LobeChat
  • Development tools such as Cursor / Claude Code / Codex CLI
  • Batch testing, automation scripts, and lightweight production use
:gear: Recommended Configuration
Enter the following as the Base URL:
Code · text
https://api.shangan9.cc.cd/v1
Use the Key generated on the site as the API Key.
OpenAI-Compatible clients are generally configured as follows:
text
API Address / Base URL:
API Key:
Your Key
Model:
Choose from the model list on the site
If the client requires the complete API address, it is generally:
https://api.shangan9.cc.cd/v1/chat/completions
## 🧪 Recommended Testing Method
We recommend first using a lightweight model to test connectivity, then gradually testing more advanced models.
### 1. Test the model list first
```bash
curl <https://api.shangan9.cc.cd/v1/models> \
  -H "Authorization: Bearer 你的KEY"
2. Then test a simple conversation
Code · bash
curl <https://api.shangan9.cc.cd/v1/chat/completions> \
  -H "Authorization: Bearer 你的KEY" \
  -H "Content-Type: application/json" \
  -d '{
    "model": "模型名",
    "messages": [
      {"role": "user", "content": "你好,简单介绍一下你自己"}
:pushpin: Trial Recommendations
To ensure everyone can use it reliably, we recommend:
  • Don’t start with high-concurrency stress testing
  • Don’t send requests in an endless loop for extended periods
  • If you encounter an error, report the model name, time, and error message
  • For programming tools, test with small tasks first before running large projects
  • If a model is unstable, switch to another model or try again later
You can report any issues directly. I can’t solve them either—the setup cost is extremely low.
:link: Access
Shangan9 AI Relay:
Everyone is welcome to give it a try.
ModelOC gpt-5.5 OpenAI · api.shangan9.cc.cd 评级 A 评分 92 风险 低 覆盖率 71.4% · 可信度 MEDIUM · 引擎 2.6.2 通过 10警告 3不确定 4 测试时间: 2026-07-02 16:54 UTC
Free
It’s already dead, error status: 402, error message: {“detail”:{“code”:“deactivated_workspace”}}
The forum one I was involved in died too. Did they kill them all?
There may still be some; wait until the update time.
Change the category from Chit-chat to Deals
What is a key?
It’s fine now—the one just now messed up the page.
They’ve all been changed to 100 bucks. The next quota reset is at 2:30 a.m.
I can’t register.
Alright, alright, that’s enough. This is my first time doing this too, haha—I’m just doing it for fun.
I can’t receive emails or authorize.
Can’t receive the verification code
Is it still usable?
Very well organized, thanks for sharing.
Everything I checked this morning was already dead.
Can it still be used?
Nothing works anymore.
What is K12?
Thanks to the boss for his selfless dedication.
It doesn’t work.
